Выберете то, что вам нужно
On the right side of the camera, remove the two silver screws using the screwdriver.
On the left side of the camera, remove the two silver screws using the screwdriver.
Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
After popping open the plastic piece, there is a screw that needs to be removed.
Remove the screw connecting the front casing to the electrical components.
On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
Remove the two screws connecting the front casing to the electrical components using a screwdriver.
Follow Step 16 and 17 from the LCD Screen pre-requisite. LCD Repair Guide
Remove the two silver screws and two black screw holding the image sensor in place.
Using a spudger, wedge the flat tipped end between the black bar and the circuit board.
Carefully lift the black bar into the vertical position.
Repeat first two bullet points for the circuit board port directly to the left of the one shown in this picture.
Use tweezers to carefully pull the electrical ribbons from the circuit board ports.
2 участников успешно повторили данное руководство.
