Sony Cyber-shot DSC-W150 LCD Screen Replacement
Выберете то, что вам нужно
  1. Sony Cyber-shot DSC-W150 LCD Screen Replacement, Back Casing: шаг 1, изображение 1 из 1
    • The screws from the camera are extremely small, so it is a good idea to have a small container to hold all the screws as you remove them.
  2. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 2, изображение 1 из 1
    • Take your screwdriver and remove the four silver bottom screws of the camera.
    • The picture shows the lens facing away from you and the LCD facing you.
  3. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 3, изображение 1 из 1
    • On the right side of the camera, remove the two silver screws using the screwdriver.
    • The picture shows the lens facing away from you and the LCD screen facing you.
  4. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 4, изображение 1 из 1
    • On the left side of the camera, remove the two silver screws using the screwdriver.
  5. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 5, изображение 1 из 1
    • Gently detach the back cover by holding onto both sides of the camera and pulling them apart.
  6. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 6, изображение 1 из 1
    • After detaching the back cover, carefully pull it off.
  7. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 7, изображение 1 из 1
    • The back cover should now be separated from the camera.
  8. Sony Cyber-shot DSC-W150 LCD Screen Replacement, Front Casing: шаг 8, изображение 1 из 1
    • Keep track of the small screws that you remove.
    • Opening, removing, and/or replacing the front casing may void your manufacturer's warranty.
  9. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 9, изображение 1 из 1
    • Remove the two screws at the top of the camera casing.
  10. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 10, изображение 1 из 1
    • After removing the screws, gently pop open the plastic piece, as shown by firmly pulling it with your fingers.
  11. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 11, изображение 1 из 1
    • After popping open the plastic piece, there is a screw that needs to be removed.
    • Remove the screw connecting the front casing to the electrical components.
  12. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 12, изображение 1 из 1
    • On the casing on the opposite side of the camera, gently loosen and remove the casing by firmly pulling with your fingers.
    • Be cautious not to break the fragile pieces or scratch the LCD screen.
  13. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 13, изображение 1 из 1
    • Remove the two screws connecting the front casing to the electrical components using a screwdriver.
  14. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 14, изображение 1 из 1
    • Gently loosen the front casing by gently using your fingers to pull it apart.
    • Be cautious not to scratch any of the exposed electrical components.
  15. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 15, изображение 1 из 1
    • Fully remove the front casing from the camera and set it aside.
  16. Sony Cyber-shot DSC-W150 LCD Screen Replacement, LCD Screen: шаг 16, изображение 1 из 1
    • The last screw is in the bottom left corner of the camera's right side.
    • Using a screwdriver, remove the last screw holding the LCD/control panel to the rest of the camera on the right-hand side.
    • It is crucial for reassembly to track which screws were removed from which holes.
  17. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 17, изображение 1 из 2 Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 17, изображение 2 из 2
    • At this point, all screws on the left and right sides of the camera should be removed.
    • Paying careful attention to the right side's electrical wiring, gently pull the left side of the LCD plate away from the rest of the camera.
    • DO NOT detach the electrical wiring connecting the right side of the LCD and the camera.
  18. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 18, изображение 1 из 1
    • This picture is used to identify the action required to release the electrical ribbons, but not the proper location for this step.
    • This step applies to the larger electrical ribbon connecting the LCD screen and circuit board.
    • Using a spudger, wedge the flat-tipped end between the black bar and the circuit board.
    • Carefully lift the black bar into the vertical position.
  19. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 19, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • After raising the black bar, the electrical ribbon should be free from its port.
    • Use tweezers to carefully pull the larger electrical ribbon from its circuit board port.
  20. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 20, изображение 1 из 1
    • The smaller electrical ribbon, to the left of the larger ribbon, does not have a black bar securing it in place.
    • Use tweezers to pull the smaller electrical ribbon carefully from its circuit board port.
  21. Sony Cyber-shot DSC-W150 LCD Screen Replacement: шаг 21, изображение 1 из 1
    • Desolder the small electrical ribbon that connects the control panel to the LCD screen.
    • Now the LCD/control panel is completely removed from the part and ready to be replaced.
Заключение
4 человек успешно провели ремонт по этому руководству.
Brent Clavin
Участник с: 04/15/10
90 Репутация
1 руководство автора
Команду
Cal Poly, Team 33-73, Johann Spring 2010 Участник Cal Poly, Team 33-73, Johann Spring 2010
CPSU-JOHANN-S10S33G73
3 членов
Автор 2 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 18
За последние 30 дней: 38
За всё время: 10,323
