Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Steps on how to replace the speaker.
Выберете то, что вам нужно
Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
Remove both batteries.
Remove the single visible screw from both sides of the camera.
Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
The LCD screen sits in two slots; one on the bottom, and one on the left edge.
Slide LCD screen from the two slots.
To remove the LCD screen, detach the orange cable from the board.
If needed, replace the LCD screen.
Remove the two screws holding down the steel back plate.
Remove steel back plate.
Disconnect the flash cable (black and white wires) before completely removing the front case.
Gently start to remove the case.
Once the cable is free, set aside the front case.
The speaker should now be clearly seen on the underside of the camera.
Gently unplug the speaker from the motherboard.
Replace the speaker.
