Введение
Disassembling Sony Cybershot DSC-W5 in order to get to the battery terminal so that it can be replaced.
Выберете то, что вам нужно
Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
Remove both batteries.
Remove the single visible screw from both sides of the camera.
Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
Remove the two screws holding the circuit board down.
The LCD screen sits in two slots; one on the bottom, and one on the left edge.
Slide LCD screen from the two slots.
To remove the LCD screen, detach the orange cable from the board.
If needed, replace the LCD screen.
Remove the two screws holding down the steel back plate.
Remove steel back plate.
Now remove the plastic plate that covers the motherboard.
Below and to the left of the viewfinder there is a vertical slot in the motherboard with a soldered connection to the flash capacitor on each side. Using a small screwdriver with an INSULATED handle, short these together for several seconds to discharge the potentially dangerous charge.
Disconnect the flash cable (black and white wires) before completely removing the front case.
Gently start to remove the case.
Once the cable is free, set aside the front case.
If the front doesn't seem to want to come away, maybe the flash cable is caught around its socket.
The speaker should now be clearly seen on the underside of the camera.
Gently unplug the speaker from the motherboard.
Replace the speaker.
Remove the orange cable connecting the battery terminal to the motherboard.
5 участников успешно повторили данное руководство.
Один комментарий
Clean the little nobs in the pattery-pack and problem solved! I also removed the black plastic ring that was on the +pole inside.
