Введение
How to replace the lens zoom unit of a Sony Cyber-shot DSC-W510.
Выберете то, что вам нужно
Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
There are five screws on the bottom of the camera and two on the side.
Pry open the screen frame using a plastic opening tool.
It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
Using your hands, pry open the LCD screen from the metal board.
Gently unplug the LCD screen from the motherboard.
Remove the screws from the metal board using the Phillips #00 screwdriver.
Pop apart the metal board using the plastic opening tool.
Peel apart the black tape from the flash bulb.
Unscrew the one screw from the motherboard.
Disconnect the two links from the camera unit to the motherboard.
Pop out the lens zoom unit from the frame by using either your thumb or an opening tool.
4 участников успешно повторили данное руководство.
