Введение
Disassembling the back cover of the camera so that we can repair components from the inside.
Запчасти
Детали не указаны.
  1. Sony Cyber-shot DSC-W55 Back Case Replacement, Battery: step 1, image 1 of 2 Sony Cyber-shot DSC-W55 Back Case Replacement, Battery: step 1, image 2 of 2
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Sony Cyber-shot DSC-W55 Back Case Replacement: step 2, image 1 of 2 Sony Cyber-shot DSC-W55 Back Case Replacement: step 2, image 2 of 2
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Back Case Replacement, Back Case: step 3, image 1 of 2 Sony Cyber-shot DSC-W55 Back Case Replacement, Back Case: step 3, image 2 of 2
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Back Case Replacement: step 4, image 1 of 2 Sony Cyber-shot DSC-W55 Back Case Replacement: step 4, image 2 of 2
    • Remove the screw with a Phillips #00 screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
  5. Sony Cyber-shot DSC-W55 Back Case Replacement: step 5, image 1 of 1
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Back Case Replacement: step 6, image 1 of 2 Sony Cyber-shot DSC-W55 Back Case Replacement: step 6, image 2 of 2
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
Заключение
Еще один человек закончил это руководство.
kkfong91
Участник с: 11.10.2010
326 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 9-20, Regan Fall 2010 Участник Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 членов
Автор 18 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 3,488
