Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
We are going to explain the steps needed and what is necessary in order to replace a broken front cover for this camera.
Запчасти
Детали не указаны.
  1. Slide the battery cover in the direction the arrow points. Pull the battery cover towards you.
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
  2. Flick the blue switch for the battery to pop out. Remove the battery from the camera.
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Using the Phillips #00 Screwdriver, remove the two screws from the caution panel. Remove that panel.
    • Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  5. Remove the screw with a Phillips #00 screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel). Remove that panel.
    • Remove the screw with a Phillips #00 screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
  6. Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  7. Gently remove the back cover. It may be a bit stiff, so use some force to remove it. Proceed with caution.
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
  8. Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
    • Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
  9. Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover. Gently remove the front cover. Put a little force to pop off the case. Proceed with caution.
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
Заключение
Еще один человек закончил это руководство.
Andrew Carter
Участник с: 11.10.2010
143 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 9-20, Regan Fall 2010 Участник Cal Poly, Team 9-20, Regan Fall 2010
CPSU-REGAN-F10S9G20
5 членов
Автор 9 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 4
За всё время: 3,067
