Введение
This guide shows step by step instructions to remove the lens part of the camera.
Выберете то, что вам нужно
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Flick the blue switch for the battery to pop out.
Remove the battery from the camera.
Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
Remove the panel.
Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
Gently remove the front cover.
Инструмент, используемый на этом этапе:Tweezers$4.99
Flip the black secure locks off. Tweezers may be necessary.
Detach the two orange cables.
17 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Thanks for this guide !
unfortunatly I thinks that my lens is broken (doesn't open anymore, it may have sand inside it)
Do you know where an if I can buy a new lens ?
Thanks for info..
Need a broken lens unit as my lens cable is broken, email me if any one wants to sell a broken lens unit. at barrettoagnelo@yahoo.com
my lens is broken/ stuck. Please let me know if you know where i can buy a replacement for it
Where can i find these len?
