Введение
This repair guide will number and display the steps to remove the Motherboard for replacement.
Выберете то, что вам нужно
Slide the battery cover in the direction the arrow points.
Pull the battery cover towards you.
Flick the blue switch for the battery to pop out.
Remove the battery from the camera.
Using the Phillips #00 Screwdriver, remove the two screws from the caution panel.
Remove that panel.
Remove the screw with a Phillips #00 screwdriver from the right side of the camera (with '3x optical zoom' engraved on the side panel).
Remove that panel.
Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
Remove the screw using a Phillips #00 screwdriver on the left side (where the "3x optical zoom" panel use to be).
Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
Gently remove the front cover.
Flip the black secure locks off. Tweezers may be necessary.
Detach the two orange cables.
Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
Remove the two orange cables on the top of the motherboard with tweezers.
Lift the motherboard out of its slot.
For the AV port, detach the bottom orange cable.
For the LCD screen, detach the top orange cable on the right side of the motherboard.
For the motherboard, detach all the orange cables.
Еще один человек закончил это руководство.
