Sony Cyber-shot DSC-W570 LCD Screen Replacement
Выберете то, что вам нужно
  1. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, Case Cover: шаг 1, изображение 1 из 1
    • Remove the two Phillips head, 2.93 mm long screws at the bottom of the camera.
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 2, изображение 1 из 1
    • Turn the camera sideways so the left side is fasning upwards, remove the two Phillips head, 2.93 mm screws.
  3. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 3, изображение 1 из 1
    • Now turn the device so the opposite side is fasning upwards and remove the last two Phillips head, 2.93 mm screws.
  4. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 4, изображение 1 из 2 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 4, изображение 2 из 2
    • To remove the front cover, use a plastic opening tool gently pry the top cover.
    • Then gently lift the cover off.
  5. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 5, изображение 1 из 2 Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 5, изображение 2 из 2
    • To remove the back case cover from the body.
    • First use a plastic opening tool gently pry along the side of the camera.
    • Then slowly and gently lift the cover off.
  6. Sony Cyber-shot DSC-W570 LCD Screen  Replacement, LCD Screen: шаг 6, изображение 1 из 1
    • These are the two cables connecting the LCD screen to the motherboard below the screen.
  7. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 7, изображение 1 из 1
    • Remove the LCD screen from the side opppsite the battery terminals. Watch for the two cords mentioned in the previous step. These will still be connected.The side will flip up as shown in the next step.
  8. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 8, изображение 1 из 1
    • Pull these two cords straight back to disconnect them from the respective housings. Caution: The housing do not need to be moved or adjusted in anyway. Do not pull the cords at an angle, it can destroy the cords and the housing. Pull Straight Back!
  9. Sony Cyber-shot DSC-W570 LCD Screen  Replacement: шаг 9, изображение 1 из 1
    • This is what the camera should look like after 2 cords and the screen have been removed. The lens cord is being held to the side for a clearer view.
Заключение
Еще один человек закончил это руководство.
Thomas Plummer
Участник с: 01/21/15
164 Репутация
1 руководство автора
Команда
USF Tampa, Team 9-1, Brown Winter 2015 Участник USF Tampa, Team 9-1, Brown Winter 2015
USFT-BROWN-W15S9G1
5 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 32
За всё время: 1,100
