Введение
Some things to consider before you work on the Sony Cyber-shot DSC W800 to replace the Button Board:
- The Button Board is an integral part of the device and any improper handling can cause issues in other parts of the camera.
- Be cautious when removing ribbon wires.
- Be sure to keep track of all pieces that are taken apart.
Выберете то, что вам нужно
Using the Spudger, remove the back panel from the device.
The loose piece circled in the picture will most likely fall off the camera housing.
Remove the two 2.15mm Phillips #000 screws from the circuit board.
Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
3 участников успешно повторили данное руководство.
4 Комментариев
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
