Введение
This guide will allow one to be able to remove the outer casing of the camera as to allow them to get to the internal parts of the DSC-WX100.
Инструменты
Запчасти
Детали не указаны.
If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
Remove all of the 1mm screws using a Philips #000 Screwdriver.
Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
Use the plastic opening tool to gently remove the front and back plates of the camera.
2 участников успешно повторили данное руководство.
