Введение
If the flash assembly is broken or not working properly, follow this guide to replace it.
Выберете то, что вам нужно
Use a PH00 screwdriver to remove the five 3.5 mm screws.
Use a PH00 screwdriver to remove the two 2.5 mm screws.
Pry back the panel to the right of the screen using a plastic opening tool.
Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
Lift flash component toward you and gently pull the ZIF cable up and away from the camera.
