Введение
This guide shows how to replace the lens assembly that may not be working properly.
Выберете то, что вам нужно
Use a PH00 screwdriver to remove the five 3.5 mm screws.
Use a PH00 screwdriver to remove the two 2.5 mm screws.
Pry back the panel to the right of the screen using a plastic opening tool.
Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
Unpin the ZIF cable by lifting the cable towards the top of the camera while pulling up towards yourself.
Pull the ZIF cable out.
2 участников успешно повторили данное руководство.
