Введение
This guide shows how to replace the camera's screen if damaged.
Выберете то, что вам нужно
Use a PH00 screwdriver to remove the five 3.5 mm screws.
Use a PH00 screwdriver to remove the two 2.5 mm screws.
Pry back the panel to the right of the screen using a plastic opening tool.
Working on the left side of the screen, pry the metal panel off from the motherboard housing using a plastic opening tool.
Еще один человек закончил это руководство.
