Введение
Make sure you have the necessary tools in order to complete the battery replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
Выберете то, что вам нужно
Begin by removing all six #00 screws holding the outer chassis together with the Phillips #00 Precision Screwdriver.
Pry the front cover off gently. Use a plastic opening tool if available.
Now pry the back cover off gently, using a plastic opening tool if available.
Access where the replacement battery will go indicated by the red square in the photo to your left
Now insert your new replacement battery
2 Комментарии к руководству
Why did you not just open the bottom battery door instead of pulling the camera apart?
I am also suprised to know that I should dis-assemble to replace battery. It maybe a joke.
