Нужны более качественные фото
Более качественные фотографии улучшат это руководство. Помогайте, делая снимки, редактируя или загружая новые!
Лучше введение
Улучши это руководство, заполнив или отредактировав его.
Введение
Перейти к шагу 1 ↓Make sure you have the necessary tools in order to complete the motherboard replacement for the Sony Cyber Shot WX80 and be sure to have a steady hand when dealing with the smaller and more fragile parts.
Выберете то, что Вам нужно
Remove all six #00 screws holding the outer chassis together with a Phillips #00 screwdriver.
Take note of the small free moving flap near the battery port seen in the first of the three photos.
Remove the front of the shell case with the spudger. Insert the spudger into the seam on the right side of the camera and pry away from the back case.
Using the spudger, repeat the process to remove the back of the case. Pry away from the front of the camera.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to remove the first of two ribbon cables holding the LCD screen in place. Pull directly out of the port.
Use tweezers to remove the second of the two ribbon cables using the same method.
The LCD screen is now detached. Gently pull it apart from the rest of the camera with your hands.
Remove the inner frame lining with tweezers.
Carefully lift the inner frame lining away from the rest of the camera with your fingers.
Use your fingers to gently lift the plate up and away from the rest of the camera.
You should now be able to see the exposed motherboard and lens.
Remove the first ribbon cable (pictured first) with tweezers. Pull gently away from the camera.
Remove the second ribbon cable (pictured second) with tweezers. Pull gently away from the camera.
Use your fingers to gently lift the lens away from the motherboard and frame.
Remove the screw (pictured first) with the #00 Phillips screwdriver.
Use tweezers to remove the last ribbon cable (pictured second). Pull gently away from the camera frame.
You should now be able to remove the motherboard from the base skeleton frame.
2 человек успешно провели ремонт по этому руководству.
