Введение
If your camera won't respond when you press the menu button, delete button, or control wheel, use this guide to replace the internal sensory panel.
Выберете то, что вам нужно
Make sure the camera is turned off.
Press the ON/OFF button to turn off the camera.
Remove 2 screws on the side of the camera.
Remove 4 screws on the bottom of the camera.
Remove 1 screw next to the eyepiece.
Tilt the screen forward.
Remove the two 1.9mm #00 screws on the left with the Phillips #00 screwdriver.
Open the back panel to view the inside of the camera.
Gently pull the orange ribbon cable to separate the two parts of the camera.
Turn the front part of the camera clockwise, so the lens is facing the right.
Gently remove the silver piece from the side of the camera. It should come out easily using your fingers.
Remove two 3.38mm #00 screws from the sensory panel with a Phillips screwdriver size #00.
The first screw is located on the left side of the panel and the second screw is located near the top of the panel.
Gently lift the orange ribbon cable with your finger to disconnect it.
Remove the sensory panel and replace it.
5 участников успешно повторили данное руководство.
5 Комментариев
I have issues when I turn the wheel to change the settings on manual mode. Would this be the same part?
Also, where can I find it? I tried to have it professionally repair and was told it needed the whole board and that it was not available any more. Thanks!
Sam, where did you find parts?
