Введение
This guide will show how to replace the camera lens on a Sony Cyber-Shot DSC-W80.
Запчасти
Никакие детали не требуются.
  1. Open the battery cover by sliding it towards you. Open the battery cover by sliding it towards you.
    • Open the battery cover by sliding it towards you.
  2. Push the purple latch with your thumb to unlock the battery.
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Remove the eight Phillips #000 screws. Remove the eight Phillips #000 screws. Remove the eight Phillips #000 screws.
    • Remove the eight Phillips #000 screws.
  5. Remove the single Phillips #000 screw found next to the battery latch.
    • Remove the single Phillips #000 screw found next to the battery latch.
  6. Remove the middle panel on the side of the device. Slowly pry the camera apart at its seem.
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  7. Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors. Once disconnected, use your fingers to lift lens out of the frame. Once disconnected, use your fingers to lift lens out of the frame.
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
Заключение
Kierra Taylor
Участник с: 21.02.2018
73 Репутация
1 Guide authored
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 3
За всё время: 61
