Введение
This guide will show you how to replace the motherboard on the Sony Cybershot DSC-W830 camera.
Выберете то, что вам нужно
Push the purple latch with your thumb to unlock the battery.
Pull the battery out.
Remove the middle panel on the side of the device.
Slowly pry the camera apart at its seem.
Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
Once disconnected, use your fingers to lift lens out of the frame.
Remove the single Phillips #000 screw.
Use your hands to remove the blue daughterboard.
Remove the two remaining ribbon cables.
Pull the motherboard from the camera.
