Введение
The lens allow for clear and consistent previews for what you are filming. Thus image quality can be compromised if either lens is compromised; maintenance of this component easy yet critical.
Выберете то, что вам нужно
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
Once all the screws are removed you can safely pry open the camera case using a spudger.
Take the half of camera containing both lens components and turn front portion towards you.
Remove the four 4.3mm Phillips #0 screws pictured.
Remove front lens and inspect for "dirt," smudges. or scratches. Use discretion, if lens appears too damaged, replace part.
With the pointed end of a plastic spudger, press latch located on the side of rear lens housing.
Once loosened gently pull and remove lens housing. The lens should now be free to inspect and replace.
In order to reassemble your device, follow these instructions in reverse order.
