Введение
The LCD screen is the side screen on your camera that flips open. It is unfortunately easily damaged permanently; here is a guide to at least check basic electronic connections.
Выберете то, что вам нужно
Remove the front facing screw adjacent to the LCD screen using a J1 Phillips screwdriver. The screw is 2.8 mm in length.
Rotate the camera screen until the screw on the bottom is clearly visible, then unscrew with a Phillips #1 screwdriver. This screw is 2.8mm in length.
Rotate camera again to find #1 Phillips head screw, the screw length is about 2.8 mm long. A J1 screwdriver is advised.
