Введение
The motherboard paramount for the proper function of the camera, basically acting like a "brain." This guide will serve as check for electronic connections, and a full removal procedure of this critical component.
Выберете то, что вам нужно
Remove all the 4.3mm screws on the bottom using a J000 Phillips screwdriver. There should be seven screws (4 silver, 2 black).
Open the dvd cover and remove the 3 4.3mm phillips screws. Including ones in the corners that may be hidden.
Once all the screws are removed you can safely pry open the camera case using a spudger.
Remove all ribbon connectors from the motherboard using tweezers. Simply grab each ribbon cable and pull straight out of the connector.
There is a hidden wire on the bottom of the board that should also be removed.
Remove 3 brown copper screws. Each copper screw has a #0 Phillips head and is 2.8mm in length.
In order to reassemble your device, follow these instructions in reverse order.
Еще один человек закончил это руководство.
