Введение
If there is a problem with the device's supply of power, the battery may need to be replaced.
Инструменты
Запчасти
Никакие детали не требуются.
Remove the five exposed 7.9 mm phillips screws with the spudger.
Punch through the warranty sticker with the spudger and remove the screw underneath.
Remove the rubber feet with the screwdriver.
Remove the screws that the rubber feet were covering.
Remove the wires with tweezers by gently pulling on the base they are attached to.
Remove the white and red wires from the battery by pulling on the base with tweezers.
Remove the battery from the case.
It will still be held down at the bottom with a piece of tape, so you may need to pull up with force.
Комментариев: 3
The one thing missing here is the new battery, which from Sony costs more than a new player! The closest fit to the size and capacity that I could find came from www.batteryspace.com product number PL-544792-1C
<http://www.batteryspace.com/Polymer-Li-I...>
Size: 5.4mm x 47mm x 95mm
with minimum 2500 mAh
I paid $8.50 each plus shipping for a total of about $23.
Carefully pull the coverings off the original pack and remove the tape over the connections. The wires to the tabs should come off with enough heating from a soldering iron. Those wires can then be soldered to the tabs of the new cells. Then cover up the connections with electrical tape and wrap the covering around the new cells. It fit back in the case perfectly, and works great. I'm just passably handy with a soldering iron, so it took me a good 60-90 minutes to carefully take the battery pack apart, resolder, and reassemble.
Can I just remove the battery permanently?
Yes Carlo, you can remove the battery and the unit will work plugged in.
mauricio -
