Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If there is a problem with the device's supply of power, the battery may need to be replaced.
Запчасти
Детали не указаны.
  1. Remove the five exposed 7.9 mm phillips screws with the spudger.
    • Remove the five exposed 7.9 mm phillips screws with the spudger.
    • Punch through the warranty sticker with the spudger and remove the screw underneath.
  2. Remove the rubber feet with the screwdriver.
    • Remove the rubber feet with the screwdriver.
    • Remove the screws that the rubber feet were covering.
  3. Lift up the cover gently.
    • Lift up the cover gently.
    • The tray is still connected to the base with wires.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Remove the wires with tweezers by gently pulling on the base they are attached to.
    • Remove the wires with tweezers by gently pulling on the base they are attached to.
  6. Identify the battery with the 2 blue stickers.
    • Identify the battery with the 2 blue stickers.
  7. Remove the white and red wires from the battery by pulling on the base with tweezers. Remove the white and red wires from the battery by pulling on the base with tweezers.
    • Remove the white and red wires from the battery by pulling on the base with tweezers.
  8. Remove the battery from the case.
    • Remove the battery from the case.
    • It will still be held down at the bottom with a piece of tape, so you may need to pull up with force.
Заключение
3 участников успешно повторили данное руководство.
Andrew Ward
Участник с: 20.01.2012
75 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-21, Maness Winter 2012 Участник Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 членов
Автор 5 руководств
Комментариев: 4
The one thing missing here is the new battery, which from Sony costs more than a new player! The closest fit to the size and capacity that I could find came from www.batteryspace.com product number PL-544792-1C
<http://www.batteryspace.com/Polymer-Li-I...>
Size: 5.4mm x 47mm x 95mm
with minimum 2500 mAh
I paid $8.50 each plus shipping for a total of about $23.
Carefully pull the coverings off the original pack and remove the tape over the connections. The wires to the tabs should come off with enough heating from a soldering iron. Those wires can then be soldered to the tabs of the new cells. Then cover up the connections with electrical tape and wrap the covering around the new cells. It fit back in the case perfectly, and works great. I'm just passably handy with a soldering iron, so it took me a good 60-90 minutes to carefully take the battery pack apart, resolder, and reassemble.
ted - Ответить
Can I just remove the battery permanently?
Carlo Velasco - Ответить
Yes Carlo, you can remove the battery and the unit will work plugged in.
mauricio -
Thanks to the excellent guidance I have managed to remove the defunct battery from my DVP-FX730 . However the DVD player will not operate by simply connecting it to the mains adaptor . My enquiries have shown it impossible to obtain a replacement battery so do I simply give up or is there a way of fixing it to work without the battery ?
john westwood - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 53
За всё время: 7,823
