Введение
To access the internals of the Sony DVP-FX730, the cover must be removed. If there is a problem with one of the components on the cover, it may need to be replaced. A screwdriver should be used to remove screws and rubber feet to remove the cover successfully.
Выберете то, что вам нужно
Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
Punch through the warranty sticker with the spudger.
Remove the screw underneath with the Phillips screwdriver.
Remove the rubber feet using the spudger.
Remove the screws that were covered by the rubber feet.
Gently remove the wires with tweezers by pulling up on the base they are attached to.
