Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
In order to access the internals of the device, the cover must be removed. If there is a problem with one of the components on the cover, it may need to be replaced.
Выберете то, что вам нужно
Remove the five exposed 7.9 mm phillips screws with the spudger.
Punch through the warranty sticker with the spudger and remove the screw underneath.
Remove the rubber feet with the screwdriver.
Remove the screws that the rubber feet were covering.
Remove the wires with tweezers by gently pulling on the base they are attached to.
