Введение
The laser in your Sony DVP-FX730 sends the DVD’s data to the lens, so that it can be translated into audio and video signals. If the device is having difficulty reading the disc, first check that it’s not due to a dirty or scratched disc. If the disc looks good, then the issue may be from a faulty or damaged laser. This guide offers step-by-step instructions for removing the laser, so that it can be replaced. All tools used in this guide are available from the IFIXIT website.
Запчасти
Детали не указаны.
  1. Remove the five exposed 7.9 mm Phillips screws using the spudger.
    • Remove the five exposed 7.9 mm Phillips screws using the spudger.
    • Punch through the warranty sticker with the spudger.
    • Remove the screw underneath.
  2. Remove the rubber feet using the screwdriver.
    • Remove the rubber feet using the screwdriver.
    • Remove the screws that the rubber feet had covered.
  3. Lift up the cover gently.
    • Lift up the cover gently.
    • The tray is still connected to the base with wires.
  4. Remove the wires with tweezers by gently pulling on the base they are attached to.
    • Remove the wires with tweezers by gently pulling on the base they are attached to.
  5. Remove the large connector. Remove the small connector.
    • Remove the large connector.
    • Remove the small connector.
  6. Remove Philips screws with the #0 Philips Screwdriver.
    • Remove Philips screws with the #0 Philips Screwdriver.
  7. Lift up the black piece connected to the wires.
    • Lift up the black piece connected to the wires.
    • Lift gently because the ribbon cable is attached to the bottom.
  8. Unlock the lock clip Unlock the lock clip
    • Unlock the lock clip
  9. Remove the T6 screws with the T6 screwdriver.
    • Remove the T6 screws with the T6 screwdriver.
  10. Gently pull the rods out with tweezers.
    • Gently pull the rods out with tweezers.
    • Be sure the laser is out of the way so that the rods can be removed.
  11. Pull laser off of the rods. Be careful when removing the rods because a fragile metal piece may break.
    • Pull laser off of the rods.
    • Be careful when removing the rods because a fragile metal piece may break.
  12. The laser is now removed.
    • The laser is now removed.
Заключение
Oliver Woolsoncroft
Участник с: 20.01.2012
75 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 11-21, Maness Winter 2012 Участник Cal Poly, Team 11-21, Maness Winter 2012
CPSU-MANESS-W12S11G21
4 членов
Автор 5 руководств
Один комментарий
where do I buy the lens?
mnmmacd - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 4,448
