Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If the monitor or screen is broken, the monitor needs to be detached from the device.
Выберете то, что вам нужно
Remove the five exposed 7.9 mm screws using a Phillips screwdriver.
Punch through the warranty sticker with the spudger.
Remove the screw underneath with the Phillips screwdriver.
Remove the rubber feet using the spudger.
Remove the screws that were covered by the rubber feet.
Gently remove the wires with tweezers by pulling up on the base they are attached to.
