Введение
This guide will teach you how to remove the button circuit board.
Выберете то, что вам нужно
Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
One 3/16" screw on the right side of the DVD player.
One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
Three 3/16" screws on the back of the DVD player.
Remove the blue tape from the processing board by gently pulling upward.
Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
Orient the DVD player so that you are facing the video and audio jacks.
Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
Orient the DVD player so the front of the DVD player is opposite of you.
Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
Orient the DVD player so the button circuit board is facing you.
Remove the four #1 Phillips screws (silver, 3/16") from the button circuit board.
Three 3/16" screws from the longer button circuit board.
One 3/16" screw from the smaller button circuit board.
Hold down the copper brace that is near the far right screw hole of the long circuit board.
Lift the longer button circuit board over the copper brace and out of its position.
Push back the black, plastic clip near the left center of the shorter button circuit board.
Pull the shorter button circuit board out of its position.
Wiggle the white cord connecting the two boards out from under the plastic pieces securing the cord.
Lift the button circuit board out of the DVD player.
2 участников успешно повторили данное руководство.
