Введение
Fixing a broken speaker in a White Sony Dream Machine AM FM Clock Radio Alarm Model ICF-C180.
Выберете то, что вам нужно
Detach the top of the plastic casing. Use a Phillips head screwdriver to unscrew the three bottom screws.
Wedge a plastic opening tool between the face of the clock and the body.
Pry open the face of the clock away from the body.
Pull upward on the blue and white ribbon cables to remove them. This will make it easier to remove the speaker.
Loosen the speaker from the remaining glue with a plastic opening tool.
Insert the plastic opening tool into the rail that holds the speaker and push down.
Еще один человек закончил это руководство.
