Введение
Screens for cellular devices are prone to cracking or shattering. There are several prerequisite steps required to access and remove the screen in place in your device. This guide will show you how to access the screen in order to replace in.
Выберете то, что вам нужно
Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
Remove the rubber plug located near the camera by gently prying upward with your fingers.
Gently lift the camera shield after removal of the rubber plug.
Pry the remaining panel to loosen its contact to the phone using a spudger.
Slide the panel upward to remove it completely.
Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
Gently pull the ribbon from the circuit.
Remove the now disconnected screen.
To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
Еще один человек закончил это руководство.
Один комментарий
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
