Введение
This guide will help you to remove the keypad from your Sony Ericsson T68i.
Выберете то, что вам нужно
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
Почти готово!
Заключение
