Введение
This guide will assist you in removing the logic board from your Sony Ericsson T68i.
Выберете то, что вам нужно
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
Remove the circuit board and screen from the device.
Use your T6 to remove the 4 screws.
Remove the plate protecting the more delicate processing parts from the logic board.
