Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide will assist you in removing the logic board from your Sony Ericsson T68i.
Запчасти
Детали не указаны.
  1. Remove the battery from the back. Remove the battery from the back.
    • Remove the battery from the back.
  2. Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips. Do not bend it too far down, or else you risk breaking the two bottom clips.
    • Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
    • Do not bend it too far down, or else you risk breaking the two bottom clips.
  3. Unscrew all four Torx T6 screws. Keep in a safe place. Keep in a safe place.
    • Unscrew all four Torx T6 screws.
    • Keep in a safe place.
  4. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart. After removing the screws, the two halves will separate. If not, then pry them gently apart.
    • After removing the screws, the two halves will separate. If not, then pry them gently apart.
  5. Remove the circuit board and screen from the device. Use your T6 to remove the 4 screws. Use your T6 to remove the 4 screws.
    • Remove the circuit board and screen from the device.
    • Use your T6 to remove the 4 screws.
  6. Remove the board and screen. Remove the board and screen. Remove the board and screen.
    • Remove the board and screen.
  7. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board. Carefully remove the plastic clips holding the screen on the board.
    • Carefully remove the plastic clips holding the screen on the board.
  8. Remove the plate protecting the more delicate processing parts from the logic board. Remove the plate protecting the more delicate processing parts from the logic board. Remove the plate protecting the more delicate processing parts from the logic board.
    • Remove the plate protecting the more delicate processing parts from the logic board.
Заключение
Tim Dascomb
Участник с: 13.04.2010
159 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 26-34, Regan Spring 2010 Участник Cal Poly, Team 26-34, Regan Spring 2010
CPSU-REGAN-S10S26G34
4 членов
Автор 13 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,957
