Введение
This guide will assist you in removing the microphone from your Sony Ericsson T68i.
Инструменты
Запчасти
Детали не указаны.
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
Next remove the circuit board and screen from the device.
Use your T6 to remove the 4 screws holding the cover on.
The microphone at the bottom of the rear housing can be levered out using a small screwdriver or any similar tool.
Еще один человек закончил это руководство.
