Введение
This guide will assist you in removing the vibration motor from your Sony Ericsson T68i.
Инструменты
Запчасти
Никакие детали не требуются.
Pry off the plastic cover from the top with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
