Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Firmly hold the phone between your fingers with your thumb on the battery cover.
Push down with your thumb until the battery cover comes off.
Unscrew the bottom two 5.4mm screws with a Torx T6 screwdriver.
Remove the two rubber casings for the top two screws with a plastic opening tool.
Unscrew these two 5.4mm screws with a Torx T6 screwdriver.
There are eight snap hooks located around the outer case. Carefully snap these to remove the outer case.
The sound box is attached to the case by two snap hooks.
Lift the sound box up to remove it from the case.
