Sony Ericsson W350a Speaker Replacement
Выберете то, что вам нужно
  1. Sony Ericsson W350a Speaker Replacement, Battery: шаг 1, изображение 1 из 2 Sony Ericsson W350a Speaker Replacement, Battery: шаг 1, изображение 2 из 2
    • Place the phone face down on a flat smooth surface so that the camera, logos, and speaker face up.
    • Using the provided notch on the bottom of the back cover, insert a plastic opening tool and lift upwards to remove the back cover of the phone.
  2. Sony Ericsson W350a Speaker Replacement: шаг 2, изображение 1 из 3 Sony Ericsson W350a Speaker Replacement: шаг 2, изображение 2 из 3 Sony Ericsson W350a Speaker Replacement: шаг 2, изображение 3 из 3
    • Set the cover to the side upon removal.
    • Insert the plastic opening tool into the crevice between the camera and the battery of the phone. Using a gentle prying motion, lift the end of the battery and remove.
    • After removal, recycle the defective battery appropriately.
  3. Sony Ericsson W350a Speaker Replacement, Speaker: шаг 3, изображение 1 из 2 Sony Ericsson W350a Speaker Replacement, Speaker: шаг 3, изображение 2 из 2
    • Flip the phone over and remove the Sony Ericsson sticker that is over the phone's ear speaker.
    • Using a T5 screwdriver, loosen and remove the two screws under the Sony Ericsson sticker by turning them counterclockwise.
  4. Sony Ericsson W350a Speaker Replacement: шаг 4, изображение 1 из 1
    • Using a mini Phillips screwdriver, remove two screws by turning them counterclockwise.
  5. Sony Ericsson W350a Speaker Replacement: шаг 5, изображение 1 из 1
    • Insert an opening tool in the bottom crack between the front and back plates and use a gentle upward pull to separate the back case from the front case.
    • Side buttons/controls may fall from their place in between the back and front casings.
  6. Sony Ericsson W350a Speaker Replacement: шаг 6, изображение 1 из 1
    • Using a T5 screwdriver, remove the two screws by turning them counterclockwise.
  7. Sony Ericsson W350a Speaker Replacement: шаг 7, изображение 1 из 2 Sony Ericsson W350a Speaker Replacement: шаг 7, изображение 2 из 2
    • Using an opening tool and a gentle outward motion, separate the front plate from the inner phone workings.
  8. Sony Ericsson W350a Speaker Replacement: шаг 8, изображение 1 из 2 Sony Ericsson W350a Speaker Replacement: шаг 8, изображение 2 из 2
    • Using a Phillips head screwdriver, remove the screw from the front number pad by turning it counterclockwise.
    • Remove the speaker from the phone.
Заключение
Еще один человек закончил это руководство.
Ldellos
Участник с: 03/12/12
112 Репутация
Автор 3 руководств
Команда
Clemson, Team 1-4, Benson Spring 2012 Участник Clemson, Team 1-4, Benson Spring 2012
CLEM-BENSON-S12S1G4
4 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,021
