Выберете то, что вам нужно
To remove the cover, use plastic removal tool on the seam of the case.
Once enough force is applied, you should hear a “click” sound which indicates that cover is loose.
Proceed with removing the battery by lifting the battery with a small plastic pry tool.
Once the old battery id removed, slide the new battery, with the positive/negative indicator facing up, in so that the contacts of the battery make contact with the contacts of the phone.
Один комментарий
Has ifixit thought about trying to make a replacement battery that would work with this? It would be good to be able to get the battery from here as well, even if it is potentially a niche market for these old phones.
