Введение
A guide on how to replace the glass on a Sony Xperia Play.
  1. Remove the 6 silver torx screws marked in red
    • Remove the 6 silver torx screws marked in red
  2. Remove the 7 black torx screws marked in yellow.
    • Remove the 7 black torx screws marked in yellow.
  3. Using a plastic prying tool, go around the outside of the phone releasing the plastic clips.
    • Using a plastic prying tool, go around the outside of the phone releasing the plastic clips.
  4. Remove the plastic housing revealing the motherboard
    • Remove the plastic housing revealing the motherboard
    • Remove the two Phillips screws.
  5. Remove the headphone jack by carefully moving the dark plastic clip on the connector to 90 degrees
    • Remove the headphone jack by carefully moving the dark plastic clip on the connector to 90 degrees
  6. Slide the phone to the open position
    • Slide the phone to the open position
  7. Remove the display connector  marked in orange using a plastic spudger to pry it upwards
    • Remove the display connector marked in orange using a plastic spudger to pry it upwards
    • Remove the connector for the front buttons by prising the retaining clip to 90 degrees
  8. Remove motherboard
    • Remove motherboard
  9. Remove the buttons from the phone
    • Remove the buttons from the phone
  10. Remove the three Phillips screws.
    • Remove the three Phillips screws.
  11. Slide the metal frame across revealing the last screw . Make sure to keep the plastic cover after removing the screw
    • Slide the metal frame across revealing the last screw . Make sure to keep the plastic cover after removing the screw
    • Disconnect the digitizer cable
  12. Insert a plastic spudger around the edge of the frame and take the lcd assembely from the glass
    • Insert a plastic spudger around the edge of the frame and take the lcd assembely from the glass
    • Using a heat gun heat around the edges of the glass to soften the glue, and use your prying tool between the glass and the frame to take the glass off.
Заключение
16 участников успешно повторили данное руководство.
Kris James
Участник с: 27.01.2012
594 Репутация
1 руководство автора
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 20
За всё время: 30,867
