Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
If your LCD display is broken or not working in this manual we will guide you how to replace it.
Выберете то, что вам нужно
Видео обзор
Remove the battery cover and the battery.
You have the 6x silver screws and 7x black screws and you can remove the rear bezel.
By using a plastic tool, disconnect the main flex cable connector. Be careful, near to the connector there are many small elements.
Disconnect the gaming keyboard flex cable.
Unscrew the 4x black screws.
Remove the black sticker on the corner and disconnect the touchscreen flex cable.
Disassemble front bezel.
Use the thin side of a plastic tool to separate the LCD display from the base bezel.
Now you are ready to install the new spare part.
I prefer to test the new spare part before the full assembly.
3 участников успешно повторили данное руководство.
