Введение
This is a short and simple guide to button cleaning and repairing
Запчасти
Никакие детали не требуются.
  1. The first step in accessing the audio and/or camera buttons is to remove the back case of the phone and then the battery
    • The first step in accessing the audio and/or camera buttons is to remove the back case of the phone and then the battery
  2. Next, remove eight 5mm screws as shown in the image. Use a T-6 bit.
    • Next, remove eight 5mm screws as shown in the image. Use a T-6 bit.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  4. Using a case opener (a guitar pick works as well), start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
    • Using a case opener (a guitar pick works as well), start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
  5. The phone should now look like this. The Volume button is indicated by the larger yellow circle, and the camera button is indicated by the smaller and lower yellow circle.
    • The phone should now look like this. The Volume button is indicated by the larger yellow circle, and the camera button is indicated by the smaller and lower yellow circle.
  6. The volume button (left) and the camera button (right) lift right out of the phone as shown in the picture. From here you can clean them or replace them.
    • The volume button (left) and the camera button (right) lift right out of the phone as shown in the picture. From here you can clean them or replace them.
Заключение
3 участников успешно повторили данное руководство.
Nick E
Участник с: 29.10.2013
149 Репутация
1 Guide authored
Команда
University of Maryland, Team 1-5, Shastany Fall 2013 Member of University of Maryland, Team 1-5, Shastany Fall 2013
UMD-SHASTANY-F13S1G5
2 членов
Автор 3 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 1
За 30 дней: 3
За всё время: 1,474
