Введение
This guide is going to show you how to replace a cracked or scratched glass screen. This guide only shows how to replace the glass, not the LCD screen.
Выберете то, что вам нужно
Using a flat head screwdriver, flip the chip to the left and remove the ribbon cable.
Remove the volume and camera buttons. Using your fingers or a screwdriver, pull off the black plastic piece on the very top of the phone.
Gently insert a flat head screw driver under the logic board and pry to remove it from the phone casing.
Using a flat head screw driver, disconnect the glue holding the left ribbon cable to the phone. Pull up the black plastic piece being pointed to in the image.
Using a flat head screwdriver, pry up the board.
Remove the power button from the top of the phone.
To reassemble your device, follow these instructions in reverse order. The pieces need to be placed exactly back into the phone as they came out or else they won't fit together correctly.
