Введение
Sony Ericsson X10 - how to disassemble the phone and replace the Touchscreen Glass.
Выберете то, что вам нужно
Видео обзор
Switch-off the phone.
Remove the battery.
Unscrew 8x T6 Torx screws.
Use a Plastic Pry or other plastic tool to unhook the back housing / bezel and remove it.
Tip - try prying it open from the top and over to the side. It can be very tight if you are doing this for the first time. The volume rocker and camera button are not part of the housing, so try going around it.
Remove the Volume Up/Down and Camera buttons.
Unhook the SIM & SD Card reader unit and disconnect the flex cable.
Remove the Audio jack connector.
Disconnect 4x flex cables:
LCD Display
Menu buttons
Touchscreen
Earpiece, Volume & Power On buttons
Use a heat gun or a hairdryer and warm the glass.
With a cutter carefully make a room between the glass and the frame to insert a Plastic Pick.
Slowly separate the Touchscreen from the frame.
Еще один человек закончил это руководство.
