Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will show the steps for replacing the LCD screen of the s710a if it has been damaged and needs to be replaced or repaired. This can also be used to check the connection between the screen and the motherboard.
Выберете то, что вам нужно
Remove the four 6mm phillips head screws located beneath the battery.
Remove the two 6mm screws on the front of the phone beneath the microphone cover.
Remove the black plastic piece on the side.
This will allow for easier access while prying.
Remove the two cable connectors using a plastic opening tool.
Place the motherboard aside in a safe location.
On the rotational assembly.
Unscrew the four 3mm screws
Unscrew the two 2.3mm screws
Lift this assembly off of the phone to allow access to the other half of the device.
Detach the cable connectors on the other end of the cables using a plastic opening tool.
Remove the plastic cover on the back of the phone using a plastic opening tool.
Remove the two 6mm screws beneath this cover.
Also remove the two 6mm screws near the top of the phone.
With face plate and LCD exposed, replace the existing cracked LCD with a new LCD if desired.
