Введение
This guide will detail how to detach the two halves of the phone, remove the LCD screen, and gain access to the main control buttons.
Accessing this part of the phone will allow you to clean or replace any parts that are dirty or damaged.
Выберете то, что вам нужно
Remove the four 6 mm screws from beneath the battery using a Phillips #00 screwdriver.
Remove the two 6 mm screws from the front of the phone beneath the microphone cover using a Phillips #00 screwdriver.
On the rotational assembly remove the following screws:
Four 3 mm screws
Two 2.3 mm screws
Lift the rotational assembly off of the phone to allow access to the other half of the device.
Detach the cable connectors on the other end of the cables using a plastic opening tool.
Remove the plastic cover on the back of the phone using an iFixit opening tool.
Remove the four 6 mm screws using a Phillips #00 screwdriver.
With the face plate and LCD screen exposed, replace the existing LCD screen with a new LCD screen.
Remove the button and pad assembly as shown.
If desired, these items can now be cleaned or replaced.
