Введение
This guide will show you how to remove the Dark Grey case that allows you access to the Motherboard.
Инструменты
Запчасти
No parts specified.
To remove the back cover, use your thumb to press down on the center of case and slide it off.
To remove the back case first remove the four screws shown with a T5 Torx screwdriver
Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
