Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide shows how to remove the Microphone.
Запчасти
Детали не указаны.
  1. To remove the back cover, use your thumb to press down on the center of case and slide it off.
    • To remove the back cover, use your thumb to press down on the center of case and slide it off.
  2. Using a fingernail lift the battery out of the phone.
    • Using a fingernail lift the battery out of the phone.
  3. Slide the sim card out with your thumb.
    • Slide the sim card out with your thumb.
  4. To remove the back case first remove the four screws shown with a T5 Torx screwdriver
    • To remove the back case first remove the four screws shown with a T5 Torx screwdriver
  5. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
    • Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
  7. Lift up towards the bottom and slide the case off.
    • Lift up towards the bottom and slide the case off.
  8. Use a plastic opening tool to lift up the brass colored panel.
    • Use a plastic opening tool to lift up the brass colored panel.
  9. Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
    • Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
  10. Work the plastic opening tool around the edges of the motherboard to release it from the clips.
    • Work the plastic opening tool around the edges of the motherboard to release it from the clips.
  11. Using a plastic opening tool lift up the keypad to remove it.
    • Using a plastic opening tool lift up the keypad to remove it.
  12. Use a plastic opening tool to lift the microphone out of its circular slot.
    • Use a plastic opening tool to lift the microphone out of its circular slot.
Заключение
Alex Serventi
Участник с: 07.10.2010
50 Репутация
Автор 13 руководств
Команда
Cal Poly, Team 5-15, Maness Fall 2010 Участник Cal Poly, Team 5-15, Maness Fall 2010
CPSU-MANESS-F10S5G15
4 членов
Автор 26 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 1,777
