Введение
This guide shows how to remove the Motherboard.
Выберете то, что вам нужно
To remove the back cover, use your thumb to press down on the center of case and slide it off.
To remove the back case first remove the four screws shown with a T5 Torx screwdriver
Using your fingernail lift up the side of the casing around the bottom of the phone to release all five of the clips.
Flip up the yellow tab using a plastic opening tool to disconnect the motherboard from the phone body.
Work the plastic opening tool around the edges of the motherboard to release it from the clips.
Еще один человек закончил это руководство.
